Failed NOX Test
Chris
10+ Year Member
I have a 1994 Mazda B3000. I failed my NOX emissions yesterday. The standard is 3.0 and my truck is at 3.30. A mechanic told my buddy to use a bottle of rubbing alcohol in an old Bronco with the same problem and it worked. If I add a bottle of rubbing alcohol to a quater tank of premium gas would that fix the problem?
i got through emissions once that way with denatured accohol in a 89 pontiac grand am quad four.don't remember the readings.don't think it will fix actual problem,that will need diagnosed.fwiw.
it should work.
i would recommend fixing the problem properly, however. NOX emission issues are usually in the EGR system...which can effect power, fuel economy, and driveability if not functioning properly.
Upcoming TRS Events
Featured Ranger Based Vehicle
