ruff stuff "Y" Link Steering Using GM 1 Ton TRE
Divh
bloomsburg PA
1949
Has anyone used the "Y" Link Steering Using GM 1 Ton TRE kit from ruffstuff and if so how did you like it any complaints i thinking getting it for my 93 ranger when i lift it vs getting skyjackers 6'' lift pitman arm
i like it.
what are your intentions?
That only works for solid axles not ttb.
I like mine. Works good.
i figured i would have to mod it to work with the ttb and i going for something that wont limit my flex and will handle on and off road well any other good options out there and tnak you for responding
Do a search for the linkage Stonecrusher was making for awhile. Several reports were it didn't fully cure bumpsteer (though it did alleviate the issues with excessive tire wear).
IMO, a K-link style setup (modified Superlift, etc.) has more to offer than anything else except maybe on a long-travel prerunner suspension (in which case you want to use a crossover or swingset style linkage).
thanks think i will go with a custom k-link style set up
