- Oct 27, 2007
- Fort Wayne, IN
Those will look nice. What size?
Sent from my HTC VLE_U using Tapatalk
Small Update for those who are following along.
Mid pipe will be here at the beginning of the week.![]()
You run traditional oil with the oil injector? You looked into running premix fuel and blocking off the oil injector?
Sent from my SPH-L900 using Tapatalk
They are two strokes too?
For the two stroke small engines we sell (that run premixed fuel) we recommend to shake either the gascan before fuelling and the unit before running.
With the ethonal that has become so incredibly popular a tiny bit of water (condensation will do it) makes the ethonal seperate out, it goes to the bottom where the pickup is. The oil mix stays with the gas on top. So then you are running a two stroke on straight alchohol... for awhile.![]()
Wrong. People pre-mix, add 2 stroke oil to their fuel, for added lubrication and prolong the apex seals/springs.
When I finally decide to go premix, probably this spring, I will be installing a kit like this.
http://www.ebay.com/itm/Mazda-RX-8-...s&fits=Model:RX-8&hash=item2ecf171f3c&vxp=mtr
