- Jan 13, 2014
Tried searching and can't seem to find a problem EXACTLY like this
I picked this truck up and it needed quite a bit of attention.
Firstly the cruise control cable held the throttle body open so it idled at 1500+rpm.
Fixed that, and made sure the tps was reading just below 0.99v fully closed.
Now, whenever you hit the throttle from an idle it'll hesitate. The idle drops down to almost stalling then it'll finally catch up and rev up.
It does this in park or in drive.
Now a little more background, just put in new plugs (old ones were blacker then black) did NOT do wires yet ( I'm broke LOL)
Did an oil change and cleaned throttle body.
Some other small issues with the truck...
The temperature gauge on the truck never seems to move. And the heat never really gets hot. My guess is a stuck open thermostat but I Havnt gotten around to checking it out.
Previous owner cut off the exhaust where the cat is and welded on an exhaust tip so it's ridiculously loud.
And lastly the speedometer was running off when I got it (seemed to run quite a bit faster then I was really going) and the other day it all together went out.
Just thought I'd share those last few problems in case anything was related!
Really want this hesitation fixed ASAP without dumping a ton of $ and guessing what will fix it.
Someone please help!
