Help me fix my truck!
Are you actually loosing coolant? Does this "smoke" smell sweet?
Some white smoke, especially on start up at this time of year, is 100% normal for an engine with cats. Cats produce water as a normal part of their operation, when water is exposed to the kinds of temps normally found in the exhaust it has this weird tendency to turn into steam.
The other thing is, if you managed to saturate the cat with coolant it can take a while to burn it all out.
i haven't checked to see if i've actually lost coolant but if the coolant in the cats scenario was the case would it only happen on idle and on start up? when i'm driving there's no smoke whatsoever but then i get to a stop light and it starts. i've been driving her all day. started her up about 8 or 10 times today and this JUST started happening 2 start ups ago.
didn't get a chance to smell the smoke yet either. i'll check brb.
she took a while to start up just now... light smoke came out a steady stream now as opposed to the big plumes of smoke that came out the 2 starts up before. and it didn't smell sweet to me... put my face right in the smoke. there IS condensation dripping from the inside of the tailpipe though... not sure if that matters
opened the rad cap this morning, coolant shot out but rad is still filled to the top. is it possible to have too much coolant in a coolant system? and maybe that's what was burning off, excess coolant?
Sounds like normal cat by product boiling off. As cat temps go up the water produced stops boiling and starts sublimating, meaning that it is turning to vapor so fast you don't see the steam.
Some pressure in a cold system is not that unusual, but it does mean you don't have a leak.....how could it hold the pressure with a leak.
If it was cold overnight and then warmed up before you opened the rad cap it would have some pressure in it.
Cooling system uses the rad cap to hold it at 14psi(could be 12-18psi, depends on the engine model) after coolant expands with heat, when pressure gets over 14psi the large valve in the rad cap is pushed open and coolant flows to the overflow tank until pressure drops below 14psi and large valve closes.
After engine is shut off pressure goes down as coolant cools and shrinks, that's when the small valve in the rad cap opens and allows coolant to flow back in from the overflow tank.
So if it was cold overnight coolant shrinks even more, so more coolant is pulled in from the overflow tank, small valve doing it's job.
Sun comes up and engine starts getting warmer, coolant expands a bit, rad cap's large valve does it's job and holds any pressure under 14psi.
You open cap and there is some pressure.
Good news is that it's a good sign that there is no blown head gasket or leak in system.
No you can not overfill a cooling system, you could over fill the overflow tank, but all that would do is to dump some coolant out the top while you were driving.
There is no connection between cooling system and intake, exhaust or oil areas.
So no "burning off" could take place unless there was a leak in the cooling system.
There is smoke and then there is vapor, smoke will hang around vapor disappears pretty fast depending on air temp and humidity, smoke is smoke so outside of a good breeze it will hang around.
Smoke coming out the exhaust pipe on acceleration after idling for 30 sec to a few minutes, could be a sign that your intake valve guide seals are wearing out, not a major issue until you are consuming alot of oil between changes or fail emission test because of it.
The valve guide seals are rubber boots in the valve cover area, they are on the top end of the valve stems, they prevent oil and oil vapor from being pulled into the intake manifold, they can get brittle as they age.
At idle the intake manifold has it's highest vacuum so that is when the most oil would be pulled in through leaking seals, when you accelerate this oil is pulled off the valve all at once and burned which produces the blueish smoke.
Vapor smoke is normal depending on temp and humidity.
All gas engines produce water in their exhaust, gas(H) and air(O) when combined and burned produces some H2O(water), this is why exhaust systems rust from the inside out.
If air is humid then engine is sucking in even more water vapor along with the air it needs to run.
All gasoline will have some water in it as well, so depending on % you may notice more vapor from one fill up to the next.
Does the smoke have a slight "oil burning smell" to it? When you really overheat an engine the piston rings will seize, and let oil get by the rings thus letting it burn a little oil. It still can be run with seized rings, it just won't have as much power, and burn a little oil.
If you really want to find out if the piston rings are still good, or not is to run a compression test on all the cylinders (write the compression numbers down). Now do another compression test (called a wet test) put a little bit of engine oil in the cylinder (the amout that the oil bottle cap holds will be enough) then test it, then do the others the same way while writing down the compression numbers down. If you see a good increase in compression after doing the "wet test" the rings are done.
perfect i'll do a compression test as soon as i slap a new head on her. after driving her around all day today i've come to accept the fact that sooner or later (feels more sooner than later) she will need a new head. I did the balloon (condom) HG test today and it fully inflated in less than 10 cranks. she's been blowing smoke almost non stop also (white smoke) out the tail pipe and i can already feel the power dying down. learned my lesson though. never again will i install a cracked head on a block unless there is a dire need. also, the radiator hoses have so much pressure built up in them after just 10 minutes of driving that they feel about ready to burst.
i'm confident that my bottom end will hold up for a long time, but i need to put a proper head on there.
what's you guys' take on that red devil/blue devil blown hadgasket fixer-upper stuff? i've heard stories of people sealing up their blown HGs and cracked heads and what not.
I have used the Rislone Head gasket fix before, once on a V8 Chevy pick-up, the truck was use a few hours 5 days a week for 9 months before I put a new head gasket in.
Saw no blockage in heater core flow or rad flow after using it and then redoing the head.
I used it in a neighbors V6 taurus he ran it for 2 years til the tranny gave up the ghost.
So no complaints on the Rislone stuff, don't know about the other brands.
One thing...follow the instructions, there is a reason to the heat up and cool down on the engine when first using this stuff.
As always a new head gasket is the best choice, anything else is a temp fix, could last a day or 5 years and that's the problem, you just don't know until it fails, lol.
