Welcome to the forum
Couple of things to check.
On the upper intake is the IAC(idle air control), fuel injected engines use a "controlled" vacuum leak to set the idle level, the IAC is a valve that opens and closes to allow air into the intake(vacuum leak), it is controlled by the computer.
Cold engine idle is usually 1,000rpm and warm engine idle 750rpm, those are preset levels in the computer, the computer tries to achieve those rpms by opening and closing the IAC.
The IAC can get dirty or sticky or quit working altogether, it is the large cylinder on the side of the upper intake, it has an electrical connector, you can unbolt it and clean it and even test it.
When first starting the engine the RPM should go up to 1,500rpm, sometimes a little higher, then drop down to 1,000(cold) or 750(warm), that is the computer testing the IAC, if this doesn't happen then IAC is stuck(or broken) or wiring has a problem.
IAC problem would not cause a lack of power.
Fuel injected engines can not use a regular "choke", no jets, so they use a temp sensor.
The ECT(engine coolant temp) sensor is a 2 wire sensor used only by the computer, there is a 1 wire sender used for the dash board temp gauge, they look similar but are not the same.
The ECT sensor tells the computer the engine is cold, the computer then switches to a rich fuel/air mix, advanced timing and increased idle.
If the ECT sensor is reporting that engine is warm all the time, then cold engine would not idle well and would lack power until it warmed up.
If ECT failed in this way the engine would run fine when warm, only cold engine would be effected.
Also check all vacuum lines for cracks and brittleness, especially the MAP sensor vacuum line.
The MAP sensor is usually on the passenger side firewall, sometimes hidden behind the wiring harness, follow the vacuum line to find it, also unplug it's electrical connector and make sure it is clean and dry.
MAP sensor plays a big role in the fuel/air mix the computer uses, it tells the computer the load the engine is under so could give the computer the wrong info if vacuum line is leaking.
Worn plugs need to be replaced, how old are they?
One other thing, anytime you work on a computer controlled engine, you must reset the computer for it to "see" any changes you might have made.
You can use a scan tool for this but most just unhook the negative battery cable for 5 minutes, this will cause the computer to "reboot" and then relearn any changes you might have made.
Some forget to do this and end up replacing sensor after sensor trying to find a problem, when they fixed it the first time but never "told" the computer to look for the change.
