- Mar 6, 2013
- Saint Clair, MI
I'm going to run through the firewall, just to the left of the brake pedal. What is the best way / safest way to get it there?
Since you have an auto, go through where the clutch master would.
There should be some sort of block off plate or plug in the firewall where a clutch master cylinder would be if the truck was a manual.
The shifter cable for the auto goes through the same hole that the clutch master mounts in on a manual trans truck. There is no block off plate.
I have been wanting to put my HAM radio in and my CB in for a some time now but could never find a path for the power and antenna out of the cab.Since you have an auto, go through where the clutch master would.
Unbolt the cover, drill a hole, add a grommet, bolt it back on.
