The be isnt really thick enough. You could weld on a bung, or do what I do with all my TTB pigs.
I drill a hole from rhe inside of the housing into the bottom mounting bolt hole, this way you can just drain it through the mounting hole....
Sent from my DROID RAZR using Tapatalk 2
So you just drill a hole from inside right into the mounting hole...i've never thought of that
Just need to bleed the brakes, try to bleed the slave cylinder, change the fluids, and a little work to the body and i will be ready to rock.
