shr3dd3r 09
- Feb 24, 2011
- Huntsville, AL
- Total Lift
- 3 Inches
- Tire Size
- 33X11.5X16 (285/75R16)
I've been troubleshooting this problem for several days now and I am running out of things to check. My 2000 Ranger 5.0 does not want to run well. It will stutter randomly and sometimes it will die completely while idling or driving.
Fuel pressure drops when this happens. I have checked the inertia switch, fuel pump relay, and verified that the pump is getting power to it. The fuel pressure also remains high for several minutes after I shut it down, so I assume the pressure regulator is good.
To date I have replaced the fuel filter and fuel pump and the problem continues. When the truck does die I can still hear the fuel pump running until I turn the key off. When the pressure does drop the power to the pump remains over 13 Volts constantly, so I don't think power is getting interrupted.
It is not losing electrical power completely, because the dash lights, head lights, etc. stay on. I am stumped but I really need to fix this ASAP. What else should I check?
