Thanks guys I'll get some video and flex pics Saturday. I have flexed it with a jack and it has more travel than the 14" front and 12" rear shocks will allow. I should have got a video today full throttle in 2nd gear is a lot of fun.
For the last 2 days the power steering fluid has been overflowing a foaming mess every time I turned it off. So today after trying to bleed it several times by turning it lock to lock and it still overflowing I made this
Clamped it around the filler neck and kept vacuum on it while turning it lock to lock. Did 3 times stopping to add fluid and it's fixed.
Leaves work plain and simple. Unless your doing koh shit i dont see the point in anything else. And even then deaver leaves are still good
My buddy keeps trying to prove his fancy link suspensions are better they cost 5x what my leaves cost and i flex just as much with less breakage. Only thing i need is a traction bar out back...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
