alwaysFlOoReD
⭐Supporting Member
- Apr 13, 2009
- '06, '11
- 3.0 V6
The hole for the ball bearing is on the shaft? The shaft is probably hardened, and I don't know for sure what the solution will be. I'd try a dremel with a diamond tip bit first or maybe a grind stone. I think there are different hardness's of grindstones so you may have to talk to someone knowledgeable. Perhaps talk to someone at an industrial supply warehouse or machine shop.
Good luck,
Richard
Good luck,
Richard
, and passenger side ones nut is completely rounded off
. I am already starting to regret the body lift
