- May 16, 2010
Hello Everyone,
Last week on my way home my 1996 Ranger 2.3L suddenly died. Instantly. It has 150,000 miles on it.
I had it towed to our local mechanic and was told the timing belt broke. He replaced the timing belt and also installed a new water pump.
I stopped in to see if it was done and he had it idling while topping off the coolant. It had a bad miss and I told him it ran great before the belt broke and had no miss.
He said it does have a cylinder #3 misfire. He said it has spark, but that cylinder is missing.
I asked him if he was sure the timing belt was installed correctly, and he said he double checked it and also had another mechanic check his work to make certain it was installed correctly.
He told me he was going to pressure test that cylinder. If it tests ok, he said the injector may be bad.
I know it's a non interference engine, so what do any of you think? Bad cylinder? Fuel injector?
Thanks for any thoughts and comments. I guess I'll just wait patiently until he gives me the pressure test results.
Nate
Nate
