- Jun 2, 2010
I have a 1986 ranger 4x4 5 speed with the 2.3l fuel injected. The problem I have is that it idles good and will start up every time. But when I give it gas it sputters and doesnt have much power. I have replaced timing belt because it was worn but lined everything up right and on the compression stroke. I put the rotor pointing at number one spark plug on the cap. Still no luck. I have put the whole distributor a tooth to the right and left of the spot where it will run and still no better. So far I have replaced the distributor, the cap and rotor button, new wires, new plugs and properly gapped. New ignition coil, cleaned the Thottle body. Checked the fuel presure and it was good. It starts up everytime but doesnt drive good at all. I put a timing light and set the base timing at 10* btdc and then hooked up the spout connector and one time it went up to 30* btdc just idling now it doesn't. So when it idles it idles ok and spits and sputters just a little but when driving it it doesnt have much power and sputters and also the enigne pings if you floor it but if you move the dizzy around a little and drive again it wont ping but still sputters and no power. Please help.
	 Welcome Visitor! Please take a few seconds and
