lil_Blue_Ford
Cut & Weld
⭐Supporting Member
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
No work today so I got to make a little progress on things....
Fixed the holes in the bracket for the drivers side axle beam pivot and did a little bit of final welding for a couple other things.
Decided to use the Energy suspension bushings so I lubed one up, assembled it and pushed it into the drivers side beam (using a large C-clamp and a piece of C channel). Then I jammed the whole mess into the bracket and stuck a temporary bolt in (I have to track down a new bolt for the pivot since I don't really want to use the fully threaded one that was in there). Mocked up my radius arm extension and all to find that I should have got a longer piece of tube, what I have is going to end up being a lil short, only about an inch and a quarter of tube is in the end of what was my stock radius arm.
On another note, I guess this should probably be self-explanitory, but the joints I bought for the frame end of my extended arms, I got a right hand thread and a left hand thread.... which side should I stick which joint?
