My Build, All Parts And Prices ***2016 Updated*** still not done...
Buddies of mine that I've known since kindergarten. And yup, once the ranger is done the cummins is going into my GMC dually.
Schweet. Need a full writeup on that one
Don't mind the bomb that went off in the shop, thats tomorrows clean up job....
Front axles back in, all welded up and painted
Track bar bind test.... 36" difference side to side and the floor got in the way to go any farther, I think I'll be good!
Housing as I was cleaning it up....
looks really good!!
Everytime I see that truck, you have put aside rent set of wheels on it. Lol
SXs are in the barn, the michelins will be my street rubber. Would have been running last night, but I have a fuel pressure issue....
Are those the same tires Rick is running on SVT?
Hope that its nothing major. You get the harness all done?
Same tread, but mine are shorter. Harness is all done, my pressure issue may be caused by the jumpers I was using to temporarily extend the wiring to the BII tank (drop in voltage?) or by the vette fuel filter/regulator (it's a cheapy, not an OEM one).... I'll figure it out if Russell doesn't first when I get off work in 18 days.
Rad came in, I'm probably gonna run Duffys doubler in front of my atlas so I have a middle trail/mud gear and then my link length should give me next to nothing from driveline length change with over 20" of wheel travel.
Busy workin saving for an acreage, and took a few days off for a wedding and to visit the gf out in Vancouver. I'll post up some pics when I get something noticeable done haha.
Got some time to work on the truck... get some more stuff together. Even with the 2" B/L it need floor surgery
I ditched the spacers and stock body mounts in favor of 3"x.250" tubing and Hi-density poly for an isolator, should be solid now with no issues for the exo it's getting later.
Next up was spinning the 2 broken bolts from my clocking ring on my atlas, dont't ask why... But, for all you ill-equipped gentlemen.... I finally found a use for a small tool!
Here's my newest driveline doohicky! D&D machine billet crawlbox, note the slotted holes so it'll run chev and standard 6 bolt pattern.
And the combo with the atlas next to the original 241 that came with my NV4500
Wow, that's freakin awesome! Duffy get his house finished? I also didn't know he was making crawl boxes. What did his kit run you?
$700 Canadian, with tax and shipping. No idea on his house, lol.
