Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
I had to move my cross member forward to the next set of holes also once the engine was in, but everything did bolt right up - that was probably one of the easiest parts except for getting the rivets out.
Was yours the other style of crossmember that sits more under the frame than inside it? Ford can do some pretty stupid things but I can't see them forcing you to cut rivets to get the tranny out... and with my crossmember you would have to. The style like my '86 parts truck you just tap out two bolts and the crossmember falls out leaving the mounting brackets in place.
Pretty sure the ATX from my Tempo weighs more than an AOD. The TK-5 from my 2.0L truck surprised me for how light it was. I also think the SOHC I4 blocks are heavier than the V6s with no cam. Maybe it was just the day I was working on things...
I have never wrangled a 4wd AOD but my A4LD wasn't proportionally lighter for its strength than a 2wd AOD.
