INFO Photos of Lifted RBV's With Different Lift & Tire Sizes
Yep. I had 33x10.50 on for about a week. Front and rear. No issues. 33x12.50 would have rubbed up front without a lift though.
Alright cool thanks. I need to step up to 33s but wasn't sure I had space in the rear without glass. Thanks.
Id do at least shackles if you're going to 33's.
Unless your truck is a street queen.
Haha... Sorry didn't quite explain myself here. I'm currently sitting on Deaver F31s with Camburg shackles and flipped hangers. This puts me back close to stock height for now. The truck won't get beat on until I get rear glass anyways, as I'm sorta in the wrong state. I dont have any inner fenders anywhere and the wheel well has a large hole in it where the top of the tire is. As long as it will fit between the front and back corners of the arch I'm good
So I went Junk Yarding this weekend and found these nice Mazda Navajo wheels WITH 30" tires on them
BUT! I was only able to buy two...:annoyed::bad:
Now I just need to hunt for two more! Anyone in the Central Coast (CA) area know of some Navajos I could get the wheels off of?
Pre key mod 1.5" crank
shackles and block in the rear
285x75r16(33x11.5x16) federal couragia MT's
2008 Ford Ranger XLT, Stock torsion keys full crank, stock rear blocks. 265 75 16 Cooper Discovery knock offs
Note: The tires did clear without cranking the torsion bars up, however they did rub on the sway bar (very lightly) at full lock.
88 B2 with 1" coil spacer's, the flares cut off, sitting on 31-10.50-15 BFG mud terrains.
89 with washer mod, 235's
6-7" suspension
1990 with 3" body and 33-12.50-15 on 15x7's the rear is a little bit low cuz of the 2.9 in the bed
31-10.50-15 on 15x10's
31-11.50-15 LTB's on 15x8's
1997 Ranger 2wd, 4" Rough Country Suspension, 32x11.50R15 Kenda Klever MT's on 15x8 Soft Eight wheels.
3" body lift, 2" coile in front, add-a-leaf and '97 Ranger block in back.
33x12.50s on AE 058 15x8 wheels
Nice looking B2 :icon_thumby:
I had a '87 B2 Eddie Bauer for a little while. I've been thinking about picking another B2 up for a trial rig / mud toy, just don't see to many of them here in FL.
