Less than 3.08 ratio?
unclejemima
10+ Year Member
I have a custom project that I'm going to use a ford 7-1/2" or 6-7/8" rear end.
I'm looking to find a gear set with a ratio somewhere in the 2.50'ish range.
Has anyone heard of or know of a aftermarket company that has something like this available or could rig something up? It doesn't have to be L/S, open diff is just fine.
Any advise would be greatly appreciated.
Thanks kindly,
-mark
well if you were going with an 8.8 I'd say yes. But I'm not sure about the 7 1/2, might want to check out older mustangs and see what they had available.
Some of the early Fords, late 60's came with 2.70-2.80 gears in the 8". Even some with the 9" came with a 2.75 gear. Have to try someone like Richmond gear for anything higher in those other rear ends.
Dave
I know older stangs had 2.73s in the 8.8
you could get 2.5xx wiht a 8 or 9 inch, im not sure wich but i had an old thunderbird with them,
Can i ask why?
Chris
I know old cars had them before overdrive transmissions came out to get halfway respectable milage, aside from that I would have no idea.
7.5&8.8 fox mustangs also had 2.73's and some lower. fox from '79 to '84 all had 7.5, '85+ v8's had 8.8, 4and 6cyl had 7.5. hope it helps. even new mustang v6 still has 7.5, v8 has 8.8
It was the 86 and newer GT's had a 8.8, the 85 GT's still had the 7.5.
Thanks guys for all the advise, this is great info!
Is the mustang 7-1/2" axle the same as in the rangers? If so, i could swap a gear set from the stang into the ranger rear end, right?
For those of you that are curious, i'm building a trike that utilizes a quad motor for power. I need a nice and simple leaf sprung rear end that is decently small, the ford ranger rear end is the best I could come up with that met that criteria. I just need to get the rear end to a lower ratio for a more respectable top speed.
A 2.73 would be about right, but i would be nice to go a bit lower. I'll contact Richmond gear to see what they can have.
I know the 7-1/2" is not the most popular, but I'm trying to keep the weight down. A 8 or 9" would be much to big.
Take care,
-mark
You are on the right track.
A Ford 7.5" axle is 130 pounds, a 8" is 160 pounds and a 9" is 205 pounds (all weights are without brakes).
Don't have weight for a Ford 6-3/4" axle.
mustangii.org has a tag decoder list that shows for 1977 that axle code WGF-AJ was a 6-3/4" with 2.73:1 gears. You might be able to put those gears in a 83-84? Ranger 6-3/4" case. Good luck finding these parts these days.
The 7.5 axle is much more common. As far as I know, Mustang / T'Bird / Cougar / fairmont 7.5" gears fit into a Ranger 7.5" case with no problems. My guess is that a Fairmont or a mid-1980s V6 T'Bird or Cougar would be the best place to look for a 2.73 or lower gear set.
drivetrain.com has a good listing of all the Fords that used the 7.5" axle.
Piper106
PS
I an looking for a 6-3/4" axle from a 83 or 84? ranger for my project also. If anyone has one, PM me here at the rangerstation.com
Randys Ring and Pinion has a 2.73:1 for the 7.5
with autos, most did and even some manuals, but '85 did have 8.8's. also, '85 auto cars were fuel injected(stock 180hp), standard were carbed(210hp stock).... i know, because i have an '85 gt carbed with 8.8!!!!!!!!!!:headbang: also, '85 was the first year for quadra shocks, only on 8.8!!!! which i also have!!!! i have 4 mustangs, i know what each one has!
somebody swapped yours, casue 85's have 7.5's. and i wouldnt be buying a 2.73 gear for a whole lot. they are everywhere used. i think i actually have a couple sets for low $$
no, they didnt. ive known the original owner, then it was my uncles, they came STOCK with 8.8's..... do a little research, but a lot of places will only tell you that they had 7.5's because most of them did!!!!! i know for a fact that the '85 had the 8.8 as an option!!!! :stop:
AHH option...you didnt say that till now. id believe that
