If it has thrown a code, it will read it. There's always a chance it has not yet. Let's cross our fingers!
Sent while I should be doing something else
Welp, no such luck finding someone to come out & scan & not gonna go fork out $$ to buy one since I was told this am that a cheap one bought @ the auto parts store will most likely not give me the EXACT problem anyhow. So, time to jack this baby up & drop that pan & take a look. Stupid question (another one, ha!), but is there a visual way to tell if the solenoid is the culprit or just replace it, refill fluid & see what happens?
Ok, so I got the pan dropped & this is what I see. As stupid as it may sound...which is the TCC solanoid that I need to remove? Also, does it pull straight out & do I have to disconnect the battery before removing it? Thanks...hopefully I'll be finished with this soon & yall can move on to bigger & better things, lol!The other piece looks to be exhaust. Try giving it a gentle pry to move it out of the way.
Ok, I know this pic kinda sucks, but it should get the point across.
#1 is the TCC solenoid. In the picture that you posted it should be the first one on the left.
As for the question of reverse, there is absolutely zero reason for the converter to be locked up in Reverse. That being the case, I believe that the hydraulic passage for the fluid used to apply the converter clutch is physically blocked off by another valve besides the one in the solenoid in Reverse.
The only real way to test the solenoid before replacing it is to remove it, put power and ground to it, and see if it clicks.
Battery disconnection is recommended and highly over rated. Heck, Ford's instructions for a tire rotation are "place vehicle in N, position on lift, and disconnect the battery". There should be some sort of retainer, possibly an entire retainer bridge, that holds the solenoid (or all of them) to the valve body. Probably two small bolts to remove it. Once that is out of the way it will pull out, but there are two or three o-ring seals on the neck that will help hold it in place. You may need to wiggle it a bit or use a small screw driver to pry it back.
Be careful taking it out, the valve body is a highly machined, very sharp piece of metal and the corners can easily slice into your fingers. Apply some clean ATF to the rings on the new unit before installation.
