- Mar 13, 2008
- southern New Jersey
Truck has rear ABS only. In a nut shell....rear brake line rusted out (very small leak, never even lost any measurable amount of brake fluid in master cylinder), replaced brake line, can't get any brake fluid to rear brakes. Problem is ABS valve/module. For no apparent reason, brake fluid all of a sudden won't flow through ABS valve. The fuse is good. Before I "fix" or replace the ABS valve, is there anything electrical I should check? Is there an ABS relay anywhere? It just seems very weird that all of a sudden the ABS valve failed right after the line was replaced. The truck has been on jack stands for 3 weeks now and I really need to get it done. Thanks.
Dave
			Dave
	 Welcome Visitor! Please take a few seconds and
