rock auto....it was $23.xx. auto-bone wanted $41.99 for the same kit. there's also a kit that comes with new bearings but that was $50 or so i think.
hard to tell what's included, there was no description on rock auto. but from what i can tell, it's got both snap rings and seals for the pitman arm and the splined shaft that the steering shaft hooks to. then it looks like there's a few outer seals and maybe some inner seals. i dont recall seeing any o-rings either and there's a few of those inside the box. you may be able to recognize more than me from the pic on the site too
it's gotta be more than $60 with bearings from advanced. autozones kit with the bearings is $75.99. and rock auto wanted $50 or $60 for it.
from what i've noticed autozone is always the cheapest of the national parts stores chains. rock auto is always a little cheaper than autozone, but they have some wierd brands sometimes.
the pitman arm i got from rock auto was a raysbestos arm that was $23.xx.....autozone wanted $42xx for the same damn thing.
If you know the part # a lot times you can get stuff from Amazon. There O2 sensors are pretty cheap I got all four sensors for the Merc for $116 shipped to my door(Rockauto was about 50 bucks more for all four). I never even knew they sold parts until a friend asked if a O2 sensor would fit his truck he linked to Amazon I was like huh?!
The box I have is in great shape and doesn't leak, but, I have it apart to drill and tap it and thought if I could find a cheap kit that included all of the outer seals and o-rings I would go ahead and replace them since they are 20 years old. That kit from Rock auto looks like it has everything I will need, thanks.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
