Anyone Put Traction Bars on A Ranger?
Southenrfirewood
10+ Year Member
Anyone ever Put Traction Bars on A Ranger? I'm big into truck pulls and my rear-end gets to bouncing forward and backwards.. Will traction bars keep it from moving around and will it affect drivability?
You're big into truck pulls, and you own a 3.0 ranger? Interesting...
i have some on my ranger. it still spins when it leaves on et streets.
James duff economy traction bars are only $100 for the kit. It might be beneficial for you to do that.
it still spins off the line and my 60 for is still high not sure what it would do with out. i have not checked them to see if they was installed right.
Well they're meant more to keep it from wheel hopping and allows you to put more power to the ground because the leafs will want to bind up less. They will definitely help in a pulling situation I think.
Thanks, Do they help?
I run those on my 347 Ranger (I wheel though). Main reason I put them on was cause at first I had lift blocks and didn't want the axle wrap. When I went with new leaves I just put them back on. They are out of the way and couldn't hurt you any....
