Rear side window seals
dusto2
scv ca
Ok so I have looked around for a while now trying to find the seals for the big side windows but nobody seams to have them any suggestions or a point in the right direction
nobody knows where i could get these seals?
Are you looking for a seal for a slider or solid glass? If so I have one for a solid glass window I'd sell you cheap.:derisive: Not sure if anyone sells them new... I'll look. Junk yards.
seals for the big side windows have them any
It would help to know what year truck you have as well as what "big side windows" you're talking about. For the door windows, you'll have to go to ford.
sorry 89 bronco II and the rear side glass those big windows in the back and the door windows i could honestly find anywhere i looked but those are in great shape
The rear window and the side windows can be found at Glassmasters. The rear window with a slider is $250 installed. Hope this helps.
can you even remove that rubber from the glass or is it glued on? I don't think you're gonna find new ones. Just gonna have to buy new glass probably.
the rubber is glued on and chances are that it cannot be removed without destroying it. the local glassmaster store said that you have to order the whole window from Ford and that is around $600. :pissedoff:
i wonder if the supercab rear pop out windows for 94-98 are interchangeable? if so, find some at a junk yard with good rubber seals and swap them out.
I got the impression hes talking about a bronco II
