- Aug 8, 2007
- Age
- 39
- Manito, IL
Awesome report. Looks like a great trip, and you got some quality time in with the lady. Win-win.
What is this that you use? Is it an app for a phone or what?
Get with the times brother! The ranger will be wheeled again. It won't see the caliber trails I'll take the Explorer on, but it will still hit some dirt.
I've got a Delorme PN-20 (now discontinued, looks like the PN-60 is the new one) with their mapping softawre. There is a bit of a learning curve to getting it to work right (at least with the version of software that I'm using), but it's awesome for navigation.
I know there is some phone apps that will do similar things, but they require cell service which isn't allways available where we play at.
On the Bronco II tank, does the Ranger pump, sending unit, etc. swap right over to the Bronco II tank or were Bronco II units needed? About to start my 1 ton swap onto my 2WD Ranger and have been reading your thread relentlessly.
Thanks for all the info!
I don't think the newest ranger pumps will fit though. The pump I am using from the 01 cab is much larger than the 94 pump
I hopefully fixed my overheating problem.
http://www.fordrangerforum.com/how-submissions/63355-explorer-radiator-swap.html
New
Old
I just did the same thing with mine. Still haven't gotten to test drive it to far..
Hey Ben, I think I might be able to help you out once again. I've got my 54 from my Trac, and i also have a 4405, which is basically a 54 with a clutch front output (torque on demand) we can pull apart for parts. They are both electric cases, but i can pull em apart to verify they have the pieces you need...
SVT
