Ok so after I pulled the timing chain cover and checked the timing I was warming the motor up to adjust the carb. It didn't want to idle so i reved it up to use the fuel in the bowl so i could set the floats then I shut it down. Well it back fired through the carb as it stoped rotating. I looked the cam, timing chain up. The specs showed that the sprockets can be advanced or retarded. It's set at 0 deg right now. Should I leave it as it is or change it? For reference it's bored .030 over, has a crain E303 cam, Pro Comp 3037 heads, weiand stealth intake and a holley 570 street avenger carb. I've tried looking it up but couldn't find anything on it so I'm hoping someone here has ran this setup and can help me. My Cell is 559-907-3703 if some one can call or text me and explain it to my ignorant ass I would greatly appreciate it!!! Also im worried about my crank case pressure. It seems to be kinda high. After I let the timing chain cover set 24 hours it started leaking from the front of the oil pan gasket on the pass side. will it go down as the motor breaks in? Im wondering what my compression should be and will I be able to tell if my rings are lined up wrong in one cylinder from a compression check or do I need to do a leak down test? Would a reg compression guage work for that?
