- Oct 27, 2007
- Fort Wayne, IN
Take all the time you need, no rush.
Are you going to have to redo your track bar seeing as your draglink will be longer or will you be fine?
Yes it will all be redone, trackbar, knuckles, tierods, pitman arm, steering box, pump....etc.
Also, I will be replacing/redoing the spring buckets to hold bump stops inside the spring, also try to get rid of the spacer on the driver side.
I just hope I will have enough extra cash to get this done this year, overtime has been very scarce lately.
But first thing is to fix the steering leak. Already gone through 3 quarts of trans fluid.
Sent from my HTC EVO 4G using Tapatalk 2
