- Mar 31, 2011
- eau claire pa
turn up the radio and go to happy place
Fiberglass squeaks?![]()
I either ignore them, listen to my 2.8 tick or let the fiancee in the truck to drown them out.
Sent from my SGH-T499 using Tapatalk 2
THe only noises I got is the crap I left in my bed, 2.9 tick, a fuzzy noise in the radio from the new alternator, screech from the alternator belt on start ups, and my exhaust pipe. This is after a cab swap too. I expected noise from everything.
Someone should tell me what to do about the alternator screech and radio noise. It is an annoyance of great proportions.
Theres usually a 2nd way to run a serpentine belt that will cause it to screech. Make sure that your running the belt the correct way. I recently had that issue when I installed a new belt. Thought I had it the correct way,as my hood & header panel are not original so Ididnt have the diagram to go from.
Thought about it for a while & then realized that I could run the belt another way & that took care of the belt screech.
