ok, heres the story, i was given an old craftsman riding mower for helping a neighbor clean out his back yard. after towing it home i began working on it, after going through the carb and replacing fuel lines it was running, but the deck was broken, one the pulley shaft housings had broke causing the belt to not grip the pullies, ok, replaced that, another 45$. works good for a couple of hours then gave it to my neighbor to use while i fix hers(engine has a bent rod)
about an hour later, i see her running up to me say theres smoke underneth it, first i think its a stuck branch, then i tell her to start it up. and crap, its comming from the PTO clutch that drives the deck.. ok, mower will still mow, the electric magnet works, does not smoke when the engine is not running or no current aplied with the engine running so its not electrical.. mower still cuts but just smokes and smells bad, not gona run it untill im sure i know what to do. first i thought it was the clutch slipping so i tighted the 3 bolts on it till there was a .012 gap like it said it should have. worked better, no smoke, untill today..
question is, do i need to reajust or could a missaligned deck/pully do it? or a stuck blade?
