Thanks to those who voted for me for TOTM!
Your welcome.
Sent from my PC36100 using Tapatalk 2
Glad to vote for ya. Ever thought about putting your shocks on quick disconnect pins and pull the shocks for wheeling?
SVT
SVT
With the proper shocks there would be zero benefits.
What steps did you take to remove your bed?
Really? Probably something along the lines of removed the bolts, removed the gas tank filler and pulled any lines attached to the underside (there shouldn't be any)
are your leaf spring shackles hardened steel?
unsure who makes it but saw it on 4x4 extreme where they but a 14 bolt into a rig & they installed a kit that would allow for more clearance. You would have to cut the pumpkin & weld in a plate & have the ring gears outer edge ground down. I beleive it allowed for 2" of clearance.
