I'm at the point where I'm setting up steering on my FW Dana 44. I already have the center link done but I am concerned on how to set up the drag link (the arm from the pitman arm to the passenger side tie rod end). I am using the ruffstuff GM 1-ton steering. So, my question is does the truck have to be on its own weight?
And, it seems like the tie rod end doesn't have any play in it. Like i can't tighten the pitman arm tie rod end and point it towards the passenger tie rod end. It seems like it has to be level for it to work.
My truck has no weight on the front end and there is exactly 12" from the pitman arm to the centerlink.
Thanks!
Thanks!
