avm hubs
bennys
i have a 2000 mazda b4000 produced 9/99, with pulse vacuum hubs,will the avm hubs listed for 98-00 ranger,and 2001-08 mazda b4000 fit my truck?
Im sure they will but they are junk i have them on my 99 ranger one broke they are made with military grade plastic so they are made out of recycled pop bottles junk. Get Warn way better
avm hubs are the only hubs available for the 98-00 rangers and b series
Warn makes hubs for the 98 -2000 ranger its about 100 more then the crapy avm hubs
they make them for the international model not the north american model
i pulled this off warn's site:
FORD
Bronco II, Ranger '83-89 E, D 23 29070 27988 39128
Explorer '90-94 D, E 27 29071 32720 39128
Ranger '90-97 E, D 27 29071 32720 39128
Bronco '66-96 B, G, H 19 9790 32720 11967
1/2 Ton Pickup '59-96 B, G, H 19 9790 32720 11967
3/4 Ton Pickup '59-75 19 9790 11967
3/4 Ton Pickup, Light Duty '77.5-97 H 19 9790 32720 11967
3/4 Ton Pickup, Heavy Duty '78-97 H 30 11690 32721 11714
1 Ton Pickup '78-97 H 30 11690 32721 11714
Super Duty (F-250/350; Excursion) '99-04 K 30 11690 11714
Courier, Ranger Int'l only '99-01 L 26 61572
MAZDA
Pickup '94-97 E 27 29071 32720
Navajo '90-94 E 27 29071 32720
B Series, Fighter, Int'l only '99-01 L 26 61572
International only; Will Not Fit Vehicle Produced in North America
Well your stockers are made out of plastic too so they are no better. I have had AVMs for 4 years, no problems. Takes all of about 3 seconds to change them out.
Sorry to necro but does anyone KNOW that they will fit? I am going through the same thing now too. Is there a difference between the '00 and '01 and newer? I don't want to order them and find out they don't fit and end up stuck with a pair of hubs I can't use.
Mid-2000 up until production stopped is equipped with a live axle, no hubs to mess with. The trade off is a slight drop in fuel economy.
I modified my stock hubs to be manual and haven't looked back since.
http://www.ford-trucks.com/article/...r_19982000_Ford_Ranger_Pulse_Vacuum_Hubs.html
Thank you kind sir, that bit of information should be on a sticky or in the tech section. So I can order with confidence that it will fit. It doesn't makes sense that they are saying the '01 and up will work as the AVM hubs specifically state thet they will not work with the live axle.
I was almost to the point of specing a Currie axle to start a SAS build.
I've got a pair of used ones I'd let go for $90(Shipped)
The truck they came off of lost an arguement with something heavier that "Attacked from above" (a really big tree)
I guess you could say it was a pyric victory because the tree left the scene in pieces
Haha:icon_rofl:
Oh btw were you ever able to get a set of those splined washers and c-clips for me?
