Battery cable replacement
schneiderz
Alpharetta GA
Hey I need to replace both of my battery cables since both are corroded and I can't unscrew them now. Anyone know how hard it is also what would you suggest I use as a replacement?
I had a corrosion issue in my negative cable a few week ago on the exploder. It was causing my electrical system to trip and made the exploder undrivable. I went to autozone(borrowed friends truck) and bought these copper terminal connecters for 3.50. I cut back the cable and ground about an inch than stripped both. I used a fresh connecter for the ground wire and crimped one of my handy dandy copper terminal connecter and all was good(probably better than) new for $3.50 and 5 minutes of work. Give this a try first I think it will solve your problem.
Ill try that but my problem is I cant take the original terminal off and its both terminals positive and negative
So are you wanting to replace the entire cable and not just the connectors? Might go to an audio place and have them make you new cables.
Sent from my LS670 using Tapatalk
Simple to remove bad cable end, just use a cut off tool or my favorite a 4" grinder w/ a cut off disc installed. A hack saw or bolt cutters is a second choice.
Start with the neg cable.
ok. Heres the real question how do I take the terminals off since I cant unbolt them?
Get something on them and snap the bolt in two. Or if nothing else works grab a hold of it with a bigger pair of pliers and twist the connector off the battery posts.
Drill a big hole to weaken it then hit it a couple time with a chisel and a hammer.
i am not personally a fan of using power tools, especially those that cut and drill, around acid filled batteries... especially those that are expensive...
i would use bolt cutters or a hacksaw, the clamps are often very soft metal and will cut easily, just do your best not to cut the posts
Another sugestion is to use marine terminals when possible they are made better physically and hold up to vibration and acids taken care of. God knows the water can be a lot harder on the rig than the highway. :) :)
