OK... so I started out with my stock 1991 Ranger XLT 4x4 Extended cab with the 4.0L OHV...
So far I removed the stock radius arms, their mounts, the front sway bar, stock coils and shocks... (none of which will get reused...)
I put Skyjacker Class II drop brackets in and mounted my TTB's on the upper holes, which I guess is for 4 inch lift while the bottoms are 6 inch...
Any opinions on this?
I didnt want the beams sitting so low, I may cut the bottoms off the brackets to give me an extra 1"-2" of ground clearence. Ground clearence is the only disadvantage I see with Drop brackets VS Cut n' Turned beams, but one advantage I do have is keeping my center U-Joint happy.
I will be building radius arms but befor I can take measurments for my beam caster at ride height I would like to put the new skyjacker adjuster bushings in and pull my nuckle caster as positive as I can. This way I can angle my TTB so its tilted forword at ride height giving my front driveshaft U-Joint a streighter angle without sacraficing wheel caster...
Please feel free to comment on my ideas, this is my first TTB build and Im trying to get it right the first time...
Im planning on centering the beams bettween the fender well to get the center, but I will have heim joints on my radius arms to make that slightly adjustible... Any better way of getting the center?
I still need to remove the plastic wheel wells and cut out the stock spring / shock tower, I will be replacing these with shock hoops which will mount coilovers, so far as I see it the bottom of the coilover will mount in front if the TTB kind of where the stock sway bar is mounted, only on new mounts...
I will be using bump stops, prob 2" unless for some reason somebody would recomend 4". Havn't got there yet but thats how my thinking is going right now... They will bump into the radius arms directly behind the bolt that mounts the radius arm to the beam.
Im going to be moving my battery and some wire/fuse box from under my hood above the wheel well so i can get more up travel, I want to run Perry's Fab n Fiber 3 Inch Fenders (Anybody know if its a 3 inch rise and 3 inch flare, cant really find that info anywhere) I like those fenders, I hate the look of the newer style fenders...
Under these fenders Id like to mount 35"x12.5"x15" BFG KM2 Mudds... I think on 15"x8" wide rims with 3.75" backspacing. Do you guys think that it will be wide enough to look good with the fender flares or should I go with 3" backspacing although than it will prob wear my wheel bearings out faster?
Anyway, im all for the comments and please give me advice!
Check out how it sits so far...
I can't comment on what your doing as I'm still learning. There is a sticky for ttb systems that seems to explain fairly well.
