- May 13, 2009
- Age
- 35
- lisle ontario
Just commenting cause i accidently un subscribed also ive heard of yota leafs as an option.
Mine too, that was a bit tounge in cheekAir shocks are way outta my budget...
You're on the common path, and it really just boils down to how high you want the truck to sit. I went with the Waggy's just so that I can get the thing to sit as low as possible, but that's certainly not the only way to do things...Gonna go with junk yard leafs. I just scored a set of Chevy 63s about 5 min ago. Off a 2011 silverado. Only 3k miles on em. $60 for the pair. But that's for the rear. For the front I'm thinking Chevy 56s ($30 a pair). But why go short up front? Won't that limit travel? I can make the 56 work easily and I think it'll have more travel than the Chevy 52s or the 47" rancho 44044. Is this correct or am I missing the concept on leafs?...
I plan to run ~8" shackle in the rear
Oh and thanks for help btw. It was your build that inspired me to tackle this feat
...for abuse military wrap/stout shackles are mandatory imo.
i wish i could do coils too, or air shocks. but that damn near doubles the price of the build.
what do you guys think of using the f250 leafs. the weight capacity is very close to the chevy 52s. but im not sure how much a spring rate will differ being that its 3" wide.
i plan to keep my lift around the same height it is now. ~6" to 8". the axle will only be moved forward 3", dont wanna relocate steering box.
....what do you guys think of using the f250 leafs. the weight capacity is very close to the chevy 52s. but im not sure how much a spring rate will differ being that its 3" wide...
I don't know how many leafs are in the F250 packs off hand, but you can allways remove a leaf or two to dial it in. Worst case is you pitch those leafs and try something else.maybe some slimmed down 70's packs....
try it.![]()
wow buddy, the new axles look great under there!
i think im going to run the rancho 44044 leaves under the front of mine, they are a 2.5 in lift waggy spring.
How do you reuse ranger tie rod? Please elaborate as this may be very useful for me
So some Dana 60s and 44s use 2.5" leafs? Hmmm never knew that. My 44 uses 3". Could I use a 2.5" spring or would that not work? Trying to find an easy way to use Chevy 52s without having to do too much fab.
