I upgraded my fuel/water separator with a Stanadyne FM100 Fuel/Water Separator. This is nice because it has a clear water bowl on the bottom. It doesn't show it in the link, but it comes with one.
I also used the Stanadyne 100 Watt side load heater. It comes on when the fuel is less than 45* and goes off once it reaches 50*.
Before:
After:
I am working on a plate to cover the bottom of the filters. It will have a small access for the water drain.
The only thing I can't figure out is when I put the fuel in the filter it goes straight into the bowl. I would assume it is supposed to just be the water in the bowl.
Before:
After:
