Wicked_Sludge
actually, they were talking about cam timing, not ignition timing.
spark knock can be caused by quite a few factors...only one of which is ignition timing.
since the ignition timing is usually determined baised on the cams position, changing your cam/valve timing would also change your ignition timing.
...since the ignition timing is usually determined baised on the cams position...
geeze, why are we even argueing about this.
in engines that use cam position sensors or distributors, the ignition timing is based on the CAM timing (which is in turn based on the piston position). only engines with a CRANK position sensor take timing readings directly from the crank.
Name a few.plenty of newer rigs base spark off the cam position sensor.
A Cam Position Sensor cannot detect a misfire. A Crank Position Sensor can detect a misfire, it shows up as a frequency change in the output of the sensor.and how is a CPS supposed to detect misfires?
Yes, but the computer does not rely on info from the cam sensor to decide WHEN to fire the coil, only which coil to fire.most rigs utilizing coil-on-plug ignition systems (eg, 4.6 and 5.4's, along with some others) rely on the CMP input to select the proper ignition coil to fire.
the DIS system utilizes inputs from both the crankshaft position sensor and the cylinder identification sensor...to control ignition timing
The CID signal provides the DIS Module with the information it needs to synchronize the ignition coils in the proper sequence (timing).
