- Apr 4, 2008
Hello all, i'm new here and have read alot of the forums here but haven't came across anything close to what i'm about to ask.(great forums btw.)
I have a 84 ranger 4x4, 2.8, and it sounds like a damn sewing machine.It runs great, has around 120k on it,don't smoke at all.Just really sounds like a bunch rocker clatter.I've had several people tell me they've owned rangers,bronco II's and thats just how they sound.Even had a local mechanic tell me the same thing. So i'm wondering if there is a way to quiet this or fix this?
Also have a question about this truck leaning on the drivers side, found a cab support rusted threw, but as far as the bed i haven't been able to find anything causing it. Are the leaf springs known to get weak??
This started out as just a little project truck i picked up cheap due to the clutch being out.Was suppose to be a cheap little work truck and has turned into a $$ trap. New clutch, pressure plate,etc. Egr, water pump,hoses,exhaust,battery,tires,master cylinder,had the heads checked due runnin above normal temp(is it true that these motors came with 2 thermostats??had 2 in mine,removed the lower one and runs fine now). and i'm sure there is more i've replaced just can't remember.
This is my first Ford i've owned, and even though its been a pain,i'm kinda fond of it. So anyway, any help you guys can give me i want to thank you in advance.
