Difference between 1998 and 2008 grill
getrdone52
10+ Year Member
Aurora, CO
Probably a stupid question but I can't really tell any difference. I'm sure there are different mounting points but I thought a newer grill would look cool on my '98. Does anybody know all the differences?
I think the grilles are the same from 98+, same mounting points and what not. the headlights would require a different header panel. But other then that you can swap fenders, hoods, grilles, and bumpers with any of the trucks from 98+ I believe. Could be wrong though.
The blinkers on the 08 are on the outside of the headlights instead of below so you'll need a new header panel as mentioned and possibly new lights too.
I'm pretty sure I've seen this done on here though.
also a new hood. since the grille is like 1 inch or more taller since 04
actually u could make a 04+ grille fit using the existing lights as long u have the 04+ hood.
the 01-03 was the only one that had the part that covers under the headlights in the same grille shell.
the 04+ has it in the panel that goes behind the grille. so if u keep your lights, theres no need for a new panel.
So all I would need is a new hood? And the '08 grille would fit in like the '98 one?
That's nice to know. I knew all the bumpers swapped out but not everything else. Thanks for the help.
The grill from 2000 are even different than the '03's, slight but different.
Dave of the Nord
2000
2003
Dave of the Nord
2000
2003
Ya I see it. Instead of the light on the bottom its just plastic.
Yes.
if u want a 04+ grille yes.
like Dave is showing, the 01-03 has a plastic "wing" under the headlights.
that would require to get the 01+ heads or do a custom cut on the grille.
As u can see the 04+ grille comes separate, as the 98-00 does.
the plastic part under the lights comes on the plastic panel that goes behind the grille, so u can keep your 98-00 lights and turns
That's a good idea on Fords part. If I come by a grille and hood I am definitely doing that. Thanks for the help man.
