- Mar 24, 2008
- Age
- 46
- Howard City Michigan
Stripped the front 60 for the new wedges, then welded the tubes to the housing and welded in the plug welds
Then put the axle under the truck, mounted the wedges and the arms on, unwelded, positioned everything where I wanted it, then tacked the wedges in place.
I also made a tie rod
Then I decided that in order for me to use these arms on this frame I either had to shorten them to put them under the frame or bend them, I bent them.
I need them under the frame for a few reasons, like no room for a crossmember, so I can tuck them up higher, and because it make my life easier haha.
I also made the lower shock mounting plates and spacers for the radius arm caps.
Now I am really waiting for the heims and track bar stuff. Once I get that and put it in, I will pretty much have a roller.
