1 Ton Explorer Sport build
Stripped the front 60 for the new wedges, then welded the tubes to the housing and welded in the plug welds
Then put the axle under the truck, mounted the wedges and the arms on, unwelded, positioned everything where I wanted it, then tacked the wedges in place.
I also made a tie rod
Then I decided that in order for me to use these arms on this frame I either had to shorten them to put them under the frame or bend them, I bent them.
I need them under the frame for a few reasons, like no room for a crossmember, so I can tuck them up higher, and because it make my life easier haha.
I also made the lower shock mounting plates and spacers for the radius arm caps.
Now I am really waiting for the heims and track bar stuff. Once I get that and put it in, I will pretty much have a roller.
Have I told you lately that I love you?!?
Umm, I don't think so.
After I made that last update I went back out and welded the wedges on for good
Then put it back under the explorer and bolted the arms on with the shock mount pads.
The arms ate still on the inside edge of the frame but I can deal with that. Just have to gusset it up, we will see. It will be another couple days till I can get out there.
Why are they advertisements in the middle of your posts Kyle?
Jim is trying to get some extra dough? Its like that everywhere with pics here.
So Al is actually going to beat me! :icon_surprised:
I must not see them because I am a premium member?
Al, get your parts for me?
I have them all in my possession. You'll get them at lunch tomorrow.
You'll be pleasantly surprised.
I'm a Premium member and I am seeing them on all the pictures, wanting us to compare the GMC Sierra against the Ford Ranger
All so, nice build
Robert
Posted from my laptop
No work was done last night, but I did get the rest of the parts, hope I can work on it a little tonight. Kids and work take up too much time lol
Cut up the track bar brackets to fit the frame and made a track bar, then tacked em all on, might move it all a litte yet
Then I went and put the jonny joints in and centered and squared the axle and mounted the frame side hangers, just tacked for now.
Almost a roller....
Gonna charge the shocks tomorrow and flex it out, do some gusseting and lots of welding....hope to have it sitting on its own weight.
Event Coverage
TRS Merch
