- Dec 23, 2007
- Oregon
- 1999 Ranger XLT
I read Barney0024's quote below. I think he has nailed down my noise as well though I haven't had time to check it out completely. My noise (passenger side only) is more like high pitched metal-on-metal though - not really a whistle. I noticed if I sprayed some lube up into the area Barney0024 describes, the noise goes away for awhile. I also notice that when I have a load in the pickup, the noise tends to come back. The wheel bearings seem fine otherwise. There is no play and the noise is constant whether I'm turning or not, and the brake pedal has no effect reducing or increasing the noise. Any other thoughts? I have a '99 4x4 Extended Cab and have converted to the AVMs (but the noise was there before the conversion as well).
That noise is coming from the wheel seal. On Rangers and B4000's with pulse vaccum lock hubs there is a seal located inside of the steering knuckle behind the hub. It is also known as a vaccum daiphram. This seal mates to the axle shaft on the backside of the steering knuckle. The design leaves it partialy exposed to dirt, water, salt etc. these seals are lubricated with wheel bearing grease. If not lubricated, as they wear they start to whistle when the axleshaft turns. Eventually the seal fails and the 4x4 ceases to operate.
Remove the hub/wheel bearing assembly and the shroud on the back of the steering knuckle. push lightly on the axle shaft until you can see the sealing surface. If the seal looks bad replace it. Check the mating surface on the axleshaft for scoring. the seal in the steering knuckle is spring loaded and if it is exposed it can score the surface on the axleshaft.
Some people will tell you that this seal doesnt matter if you have changed to manual locking hubs. This is not true. Even though the hub/wheel bearing assembly is a sealed unit there is one roller bearing pressed in the hub that the axleshaft rotates in. If that goes you can damage the axleshaft and that repair isnt fun to do.
My 4x4 stopped working on my 98. I ended up replacing the hub and seal after all kinds of other parts were replaced. the cause of all the problems was that stupid seal. A $50 part at ford cost me hundreds of dollars.
Hope this helps
