- Oct 10, 2010
Wow, this turned into a Front/Rear shackle debate in a hurry, so I’m not going to touch that
Slo-vo, What are you going to be doing for steering? When I pushed my front end forward 3", the Drag link/Tie Rod gets really damn close to each other, and I don’t think you can push it much father forward than that without either going full hydro, or moving the box forward. This is with the High steer setup that puts everything in front of the axle, if you do a Helicopter type setup (Tie Rod behind the axle) life should be good.
Just an FYI, and yes, I’ll get those leaf measurements for you today
