Blake.
Well figured it was time to start one of these.
what i have to work with-
1986 Bronco II
2.9L v6
5-speed trans
ES transfer case
stock gears
stock axels
lifted by the PO
and now lets throw in some variety
3/5 of my "garage"
The
The Plan (realistic)
Build a capable yet street-able trail rig.
manual t-case swap
"half" doors
pre-runner style front bumper
mount the KC lights i've had forever
gut the inside and "waterproof" it
re-do the suspension right and achieve just enough lift to clear 35's with minor trimming
re-gear to turn those meats
lockers front and rear.
Extra stuff that would be cool
sliders
rear tube bumper
make a new dash
chopped top and cage
Background
Once upon a hot as hell day in south GA July, I traded a Honda Recon that i snorkeled for this truck.
Reviving the Juice Box
PO brought it to the house and the next day i was screwing with the transfer case shift motor. It will turn when the low range button is pushed, I dont know about 4hi bc that button does not work, and i had no 2wd. Did i mention the truck wont move at all? Well i grew tired of messing with that and decided to try to turn the shaft manually. VISE GRIPS
but the transfer case would not click into gear. it felt like the shaft was sprung. when i would turn it then let go, it would spin itself back to the original position.
i already really did not like the fact it was push button 4x4 and With all the searches I had done and everything i read i grew to dislike it even more. I decided to search for a manual t-case.
after calling every Junk Yard in my phone book (i believe there's about 12), I only found 3 that had 80's model B2's and rangers. and only 2 of the 3 had a manual transfer case. and only 1 of the two had everything i needed to do the swap. he wanted a little too much for my pocket and i decided to check the all expansive interweb.
Found a member on here who is parting out his truck, The_Dealer. Meeting up monday to get a t-case and everything i need to do the swap, 2 doors with all the guts and both panels, and a rear hatch with the glass that opens.
tuesday i should have the case in and be able to drive the truck for the first time. also i will start on those half doors. hopefully will have at least one of the half doors done by the next week.
well that's where i stand at the moment.
1986 Bronco II
2.9L v6
5-speed trans
ES transfer case
stock gears
stock axels
lifted by the PO
3/5 of my "garage"
manual t-case swap
"half" doors
sliders
rear tube bumper
make a new dash
Background
