Noob ? can I convert a 1354 SOTF to manual?
Andy D
10+ Year Member
Marshfield MA
to prevent Found On the Road Dead, Fix Or Repair Daily
I want to revive the 4wd on my 94 The shift motor is missing. Can I covert to a stick. TIA
Yes. By getting a manual shift transfer case. The case internals are different.
Look at the link I posted...you can shift it from INSIDE the truck...its a bit pricey though...around $300
The link you posted is broken. :bawling:
IMO the shifter sucks because...."you have to crawl under the truck"
So it's ok to get out and lock in manual HUBS before you hit a mudhole, but you wait until you're ALREADY stuck in the mud to shift into 4WD and complain about crawling under? IT'S ON THE WAY TO THE FRONT OF THE TRUCK!!!!!!!:icon_rofl::icon_rofl: Just lock everything in BEFORE you hit the rough spots, or, as the forum discussing it says, carry it as a "just in case" for if your motor fails on the trail. It doesn't seem to be intended for a fulltime permanent solution.
Or....
Just get another junkyard motor. The tech library shows how to take one apart and clean it good as new....
http://www.therangerstation.com/tech_library/TCaseshiftmotor.htm
Walking thru mud isn't the same as crawling thru it. Besides that you can run it from inside the cab.
No need to have as a spare, you can manually turn the shaft that the motor usually turns. Just remove the motor and turn the shaft.
i like that shifter cable thing in the link.. to bad i'm not paying $300 for it..
