My Build, All Parts And Prices ***2016 Updated*** still not done...
nice progress:icon_thumby::icon_thumby:
keep up the good work......
l8r, John
Shock hoop mockup, would have had them all bent up and tacked in tonight but I found a shitty repair weld on the 2" bender die and it let loose on me.... Yay for flying parts!
Nice work
Shit flyin apart under high pressure is always fun...
All that time that is all you have to tease me with???
I'm appalled :D
Here's the permanent version.... Might even be able to keep my stock washer-fluid and coolant resevoir! The tube on the front of the frame that the hoop ties into goes all the way through both frame rails, for a swaybar once the rest is done.
how are you gonna be able to sell this to some guy down south if it dont have ac?
It'll be fast enough to get you somewhere with A/C from any point A-point B in a hurry? :dunno:
Not much of a worry though, I'll be taking this thing to my grave :thefinger:
Same here...my truck is with me till the end.
so whats the 0-60 time like now?
sweet build cant wait to see it done
Got the GM fuse box and ECM mocked in, gonna wire the rangers underhood fuse box into the GM one. The ECM fit's nicely in front of the battery tray in the gap to the header panel.
is that going to be a water proof enough area? i remember in the videos you had this thing in some fairly deep mud id hate to see you fry the computer
According to my GM guy the ECM is waterproof and has weatherpack connections....It's also gonna get a thorough coating of dialectric grease to keep as much water out as I can.
That being said, I'm making damn sure my wheel wells are sealed up much better then before! I'm thinking full aluminum inner fenderwells with rubber to seal around the shocks.
wheel wells?
what are those?
Event Coverage
TRS Merch
