lethal-threat-b288's b2 and ranger builds
Poser shots now
My electric fan upgrade. Fan is from a 95 ford Taurus 3.8L v6 it's a 2 speed hi&lo fan I have Made a harness strong enough to support the fan in both speeds 1 relay for hi and 1 for low and I have a 3 position switch. It's hooked up and tested out Awsome! My 2.9 runs at 180 on low and 160 on high and I have more power now. I highly recommend doing this regardless of engine size.
And I found these in a junkyard today!
I like that b2 and i wouldnt mind havin that tire/wheel combo.
id like the wheels better if they were offset diffrently. more twards the out not tucked in. i want some steel wheels now, and to top it off i have an eletrical issue now, i have no power inside it
also a little update: i got a throttle body from an 86 2.9L ranger its way bigger diamiter than my 88's ill be installing it after i get er goin again. keep an eye out!
So. I got er fixed and goin again!!! Little yellow bugger that I have no clue what it is but I got it fixed... Also I installed the throttle body.
Nice looking rigs you got there...i like the blue white combo.
ya i have wanted to do that to mine for a while but at least around where i live there are already a few rigs that are od green, and my brown and black stand out a bit LOL.
Not saying OD is bad it look freaking sweet!
I had an 89 that was brown. Rusted out and I broke both the upper rear shock mounts. Then rolled it goin round a turn on my old mini tuff truck track, rolled it back over cranked it up after a few mins it rattled for a min then back at it! Didn't even break any glass. I do miss that dagum 5speed trans tho, im debating the 5speed swap in mine but only if I get my 2.9 rebuilt..
Little update: my ranger is getting a 3" BL installed in a week or so and in a couple months it'll have a 4" suspension kit installed. Making a prerunner :D
Looking good man! i keep debating if i should get some for my truck
