- Nov 25, 2010
- Northern IL
I just replaced my clutch this weekend. My exhaust wouldn't unbolt so I cut it clean in between the o2's and the manifolds. Unplugged my o2's and pulled the system free. The sensor on the drivers side wasn't tightened down when I pulled it out. I cut the bolts out that held the flanges, drilled them out, welded my exhaust back together outside of the truck, and bolted it back in with new bolts. The only other thing I did to the engine this weekend was change the fuel filter and change the oil. I test drove it around the block when I was done and everything checked out. Clutch worked. No codes. Then on my way to work this morning, after 10-15 minutes, I find myself struggling to do 55 in third gear. Sounds like it's misfiring bad or something. Then all the sudden it will fire on all 6 and take off like nothing. I checked codes. 136 which is something with the o2 sensors, and 116 which is a temp sensor or something else unrelated to my problem. What gives?
