bobbywalter
TRS Technical Staff
TRS 25th Anniversary
Ugly Truck of Month
- Aug 9, 2007
- woodhaven mi
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
7.5's dont take much throttle to pop if done regularly..
did you look at is and see if the r&p are tore up or not? pop the cover and look at it first..or take it and have it looked at. otherwise you may be wasting your time.
if you are located near mi a good explorer axle is @ 100 bux if you pull it. have the mount put on for under a 100 and you will have a better setup..
but the busted spider thing will still be possible. i tore em up too much and went bigger yet so look and research a bit.
