- Jul 11, 2009
- Tampa, FL
First off I had to get rid of my 93 on 35's cause of the rising gas prices and I picked up this neat little 2wd 2.5L I'm looking to clear a 265/70/16 tire. Since this is my daily driver and will NEVER see any trails I were thinking about going with a simple coil spring spacer for the front (Out back will be a set of 2" shackles) I've searched around a bit and I've found the coil spring spacer on Ebay..How does a 1" thick coil spacer installed on the bottom of the spring give you 3" of lift? Has anyone ever used these spacers? Are they sketchy? I'd much rather purchase a set of 2" or so lift springs but I haven't been able to find any. I dont really want to install a body lift right now because the shocks probably need replacing soon Any help?
