- Dec 10, 2010
- Ontario, Canada
I like
Very good job if only I had the money to do something like that.
I likeVery good job if only I had the money to do something like that.
I have the same problem with my wheels...I just painted my spindle and dustcap real nice to go with the hubcap. It takes A LOT MORE than a 1/4" to clear, and you can't really space out that far on our trucks because mustang wheels stick out a little bit as it is.
How did they look with the caps on them?
i haven't had the caps on yet, those will be the last thing to go on when the truck is done, just to cut down on the risk of having to take them off again and chipping them or something.
, but it turns out it was worse than that. The very top cooling tube was leaking at the solder joint at the outside corner.
Not a very big leak, more of a "squeaker", but a leak nonetheless. And to make it worse, none of my welding skills/technology could fix it if I wanted to.
I packed that puddy into that tube corner and I hope that "seals" the deal. Anyone?........Anyone?
What's this?? A piece of aluminum that you can't weld?? What the hell
Oh, and by the way...
SVT
Pics will come, but only after I'm finished.
